Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Steve A.
Thread: building a zvex SHO clone, is there anything I should know about the mosfet?
    Sep 2010
    Florida
    880
    Found a schematic that shows a BS170 transistor. Looking at Newark there are several to choose from. Is there anything I should know before ordering them?
    This is the one I selected just because it was first on the list. I know very little about transistors and zero about mosfets.
    http://www.newark.com/fairchild-semi...-to/dp/58K8772
    ~Semi-No0b Hobbyist~
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    28,873
    perhaps you could provie the schematic for your project?
    3,511
    Something you should know?
    Yes. MosFets are static sensitive, so don't wear phentex slippers and drag your feet across shag rugs. They're reasonably hardy, but the trick in early stages of pedal-building is to provide yourself with assurances that some sources of potential non-functioning can be safelyruled out, such that you can focus your attention on those few things that might still matter.
    So, just to be able to say "It's not that", when the inevitable troubleshooting happens, install a socket and insert the BS170 into the socket once everything is soldered up.
    Sep 2010
    Florida
    880
    Here's the schematic I'm following.
    https://hotbottles.files.wordpress.c...3/zvex_sho.gif
    I'm in Florida and it doesn't usually get dry enough to have problems with static (I think?). I never get a charge from touching objects like I have in other climates, fwiw.
    Supporting Member Steve A.'s Avatar
    3,957
    perhaps you could provide the schematic for your project?
    I have no idea which schematic mort used but the circuit is very simple for a pedal that sells for $150. Here is a very comprehensive link...
    http://revolutiondeux.blogspot.com/2...rd-on-sho.html
    ... and my Evernote re-creation of the page with all of the schematics and embedded links which can be viewed or downloaded:
    https://www.evernote.com/shard/s300/...b1adfb590d727c
    Steve Ahola
    mort likes this.
  1. SHO into TU-2 issues
    By ninjadave7 in forum Music Electronics
    Last Post: 03-21-2012, 07:53 PM
  2. Building a peavey 6505 clone
    By disschord in forum Build Your Amp
    Last Post: 06-02-2010, 05:05 PM
  3. Building a traynor based clone
    By punchdrunk in forum Theory & Design
    Last Post: 08-01-2009, 02:53 PM
  4. Zvex Nano Head
    By calis in forum Guitar Amps
    Last Post: 10-10-2008, 12:07 PM
  5. Building a Univox Square Wave Clone
    By beastmaster in forum Guitar Effects
    Last Post: 03-23-2007, 09:16 PM
