Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders
Old 05-28-2006, 07:50 PM   #1
scole's Avatar
introducing delcano 45 by scott amplification
ok so its only a 5f4
http://pg.photos.yahoo.com/ph/scole9.../ph//my_photos
scole is offline   Reply With Quote
Old 05-30-2006, 04:48 PM   #2
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Just a 5F4?
The 5F4 (and the like) is still one of my favorite tweed Fender amps....
I think they are right at the very start of what we think of as modern sounding, vacuum tube guitar amps.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 06-02-2006, 09:56 PM   #3
How did you make the board? Did you make your own template, or buy one?
tubelovin is offline   Reply With Quote
Old 06-02-2006, 11:20 PM   #4
scole's Avatar
5f4 board
i made the board myself, since this amp is a reverse layout like a jtm45, i drew the board with a cad program, printed it out, taped it to the board material and drilled. i ordered the eyelets from mouser. i counter sink the bottom side of the holes, i used a large center punch to flare the eyelets into place. the center punch and the couner sink are the same angle. the board material comes from mcmaster carr. if you need a drawing of the board let me know.
Old 06-04-2006, 09:34 PM   #5
What type of material is it? How much did you pay? I'm interestede in making my own boards, because I keep getting crappy boards from mojo. I think I would like to go with black though. I checked out that mcmaster carr site lots of good stuff there, thanks for the info.
Old 06-05-2006, 07:11 PM   #6
scole's Avatar
board material
heres the part number 8557K152, its 9 dollars, 1/8 thick, 3 inches wide by 24 inches long, enough to make two boards.
