Results 1 to 8 of 8
Thread: Crate BT-100 Blows Fuse as soon as it's turned on
    New Member
    Apr 2017
    4
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I have a Crate BT-100 Bass Amp that blows the fuse as soon as it's turned on. It seems to be shorted to ground, and component on the board shows an ohm reding to ground.
    0 Not allowed! Not allowed!
    Jun 2007
    4,990
    Thumbs Up/Down
    Received: 10/0
    Given: 4/0
    Welcome to the place.
    When an amp blows fuses at turn on, that usually means a shorted output transistor or a shorted power supply diode. It will take some work to figure out what your problem is.
    What sorts of experience do you have in repairing electronics stuff and what sorts of test equipment to you have?
    New Member
    Apr 2017
    4
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Bill, I'm a Network Engineer
    Quote Originally Posted by 52 Bill View Post
    I've repaired plenty of computers, monitors a,d switches/routers. I have a multimeter. I also have a desoldering station and soldering iron. The only power supply repair I have done is for bad caps. I do have the schematic save on my laptop.
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    1,767
    Thumbs Up/Down
    Received: 22/0
    Given: 15/0
    I think you should build a Light Bulb Limiter (aka Dim Bulb Tester). Whenever you have an amp that is blowing fuses the Light Bulb Limiter will help limit current if a short is present and will save your fuse. Also, once you fix the problem the first power up of the amp can be questionable still. With the limiter in place it can help prevent damage to the repaired amp if there might be anything shorted that you missed. So do a search for Light Bulb Limiter and build one. Stick to 60-100 watt incandescent light bulbs.
    New Member
    Apr 2017
    4
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I will try this tomorrow.
    Quote Originally Posted by DrGonz78 View Post
    I'll post the results
    Thanks!
    Jun 2007
    4,990
    Thumbs Up/Down
    Received: 10/0
    Given: 4/0
    It will be helpful if you post the schematic here, then we can all refer to the same part numbers, etc. when discussing what to check and test.
  7. #7
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 19/0
    Given: 2/0
    +1 on building a bulb limiter.
    A couple of other points; Don't power the amp on with a speaker or other load connected. Also, to check if one or more of the output transistors are shorted, connect your bulb limiter and with your DMM probes connected to the speaker output briefly turn on the amp and measure if there's any DC on the output. If there's no DC you most likely have a PSU fault. The amp will 'hold' without blowing the fuse with a bulb limiter connected, but it's not a good idea to leave it running like this for more than a few seconds.
  8. #8
    New Member
    Apr 2017
    4
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Crate BT-100 Schematics and parts list
    crate_bt100_sch_and_parts.pdf
  1. Workingman's 15 blew a fuse when turned on. (help me troubleshoot?)
    By Stratapastor in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-03-2017, 05:19 AM
  2. Tsl 602 pops fuse when turned off
    By madkatb in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-11-2015, 02:36 PM
  3. Replies: 8
    Last Post: 03-23-2012, 03:39 AM
  4. B-52 AT100 very low volume/fuse blows when standby turned off
    By godwang in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2009, 12:34 AM
  5. Acoustic 370 blows internal fuse when turned on
    By KeyWestBassPlayer in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-24-2009, 07:11 PM
