Results 1 to 6 of 6
Thread: DIY digital noise blocker
    Senior Member Guitarist's Avatar
    Jul 2006
    506
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I have a digital delay pedal that make a whistle/whine though it is on an isolated, toroidial power supply. Any fixes. Maybe add a 10Ω resistor to float the 1/4 cable coming in?
    Apparently this type of noise is increasingly common.
    thanks
    0 Not allowed! Not allowed!
    3,658
    Thumbs Up/Down
    Received: 31/1
    Given: 3/0
    Is it sharing power with any other pedals that use some form of high-frequency clock?
    Supporting Member
    Dec 2009
    UK
    3,253
    Thumbs Up/Down
    Received: 18/0
    Given: 2/0
    The first thing I check with this situation is run the pedal off a battery (if this is possible). Keep everything else the same. If I still get noise then I know it's not a straightforward fix. The better isolated power supplies use a separate tap for each DC circuit, but they can share a common ground. With the unit powered off, check the resistance between grounds to see if they are shared, or have a resistance between them.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,197
    Thumbs Up/Down
    Received: 236/3
    Given: 249/4
    Being a digital pedal, clock noise artifacta might well be internal, nd not supply related.
    Even non digital flangers are famous for swooshing sound/noise even with no signal input.
    Chorus pedals too.
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    540
    Thumbs Up/Down
    Received: 16/0
    Given: 20/0
    PT2399 comes to mind. What kind of pedal is it?
    Jul 2006
    506
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    OK, I made some changes tried with a battery then back again and it seems to be fixed somehow. The V12 Digitech power supply is totally isolated, even grounds. From the manual, the Digitech Hardwire DL-8 digital delay uses only about 50mA, which seems conservative.
    I completely reworked the pedalboard—which took hours—found a cable that had that black film wrap over the center and I hadn't completely stripped that and it was partly shorting, so it measured 4kΩ and that was dragging down my clean channel volume.
    A trick I used, was to send some highs to ground on the internal, engaged-On switch of the MXR phaser (leads only, like Jeff Waters). Thus solos are darker and creamier.
    Again, thanks for the advice!
  1. Fender Vibro Champ XD - reverb/delay settings making digital noise!
    By acorkos in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-27-2017, 01:56 AM
  2. DIY Digital pot for tube amps
    By GainFreak in forum Theory & Design
    Last Post: 11-01-2010, 04:24 PM
  3. grid blocker question
    By daz in forum Theory & Design
    Last Post: 03-07-2010, 12:06 AM
  4. Beam Blocker Design
    By tubeswell in forum Theory & Design
    Last Post: 03-04-2008, 12:35 PM
  5. Noise Reduction DIY >not gated< DIY?
    By orson in forum Guitar Tech
    Last Post: 06-28-2006, 09:59 PM
