Results 1 to 27 of 27
Like Tree13Likes
  • 1 Post By Enzo
  • 1 Post By tedmich
  • 1 Post By Leo_Gnardo
  • 4 Post By tedmich
  • 1 Post By Axtman
  • 2 Post By Enzo
  • 3 Post By Axtman
Thread: Best glue for capacitors?
    Supporting Member
    Feb 2007
    Seattle WA
    273
    What is the best glue for adhering large electrolytic capacitors to a PC board in order to prevent vibration from breaking the leads (and solder joints)?
    Nov 2013
    84
    there is a glue for electronics,i use silicon for mirrors.
    Supporting Member
    Dec 2009
    UK
    3,025
    For axial caps I use mainly clear silicone, as per Fender. For radials usually hot-melt. Depends on the proximity to other components, though. You don't want hot-melt softening under heat if its close to a hot component. If using silicone either use the non-acetic acid type, or allow it to fully cure before reassembly.
    There are some superb industrial products, but I haven't been able to identify them. Roland uses a pale yellow, super rubbery and extremely tenacious product that I would like to get hold of. It sticks anything to everything.
    Banned
    Aug 2017
    1
    Check Out this Instant Plastic Glue
    https://www.amazon.com/E-Z-Bond-Fill.../dp/B01GWFFEU2
    Regards from
    (spam link removed by tboy)
    Supporting Member
    Feb 2007
    Seattle WA
    273
    Jiophone,
    Thanks, but the product you recommended (cyanoacrylate) is thick "Krazy/Super Glue". I am looking for a glue that is not permanent, since someone is going to have to change the capacitors years later.
    I hear people talk about using hot melt glue, but I have serviced amps where the hot melt glue has come loose and is rattling around in the amp chassis. Hot glue also tends to dry hard and I am looking for a glue that has a bit of a vibration dampening effect.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,180
    No, hard it good. What you don't want is the cap able to move differently from the board it is on. You want board and cap to move as one. If you leave a little flex in things then the cap can bend its leads, even if just a little, and that leads to broken solder or broken leads.
    Super glue is not permanent. SUper glue has great tensile strength, they used to show one drop of glue holding a guy by the hard hat. Big 200 pound guy wouldn't pull the glue apart. But what they don't tell you is the stuff has poor shear strength. If that guy wants to pop loose, all he needs to do it twist his hat.
    So if I glue two blocks together and want them apart, I don't pull them apart, I whack one on the side and the break free.
    Hot melt may break free in some amps, but how about the thousands of amps that didn't happen? NO glue in the world holds 100% of the time. SIlicone unsticks now and then too. I would use either silicone or hot melt myself, and not agonize if I made the right choice.
    But I wouldn't use super glue for this either.
    bob p likes this.
  7. #7
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,111
    Quote Originally Posted by jiophone View Post
    cute little AI, linking to something with a couple words matched, sig links to crappy Indian cell phone company I guess its better than an instant boner pill link...
    I've always used hot melt on caps but I've been using this lately,
    makes a very elastomeric shock absorbing silicone cushion, quite soft but sticks well, great at keeping chokes from humming
    nsubulysses likes this.
  8. #8
    Supporting Member Steve A.'s Avatar
    4,027
    Not needed here but handy to have around...
    I've been using "5 Second Fix" for all sorts of things, like to secure speaker mounting screws in a cab to ensure that they don't vibrate lose. (Hey, Egnator used a dab of some sort of glue on these screws and I figured what the heck...) The stuff is great but I wait for it to go on sale for $5.99 or less.
    5 Second Fix (5SF) is a liquid bonding agent, a thick liquid which is cured in a few seconds using the UV light on the other end of the dispenser pen.
    5 Second Fix - Fix, fill, seal, and repair virtually anything in 5 seconds or less! - As Seen On TV
    Cons: Since the UV light must reach the stuff for opaque objects you need to use many thin layers.
    • My first project was to repair cracks in the lip of a rubbery plastic trash can. Nope- it did not stick well to that kind of plastic so I went back to using Gorilla brand Clear Repair Tape (highly recommended for assorted repairs!)
    Pros: I just used 5SF on a small chip on a guitar as a temporary measure to keep it from getting worse before I can get around to fixing it right.
    • I need to do the same on a small ding on my car next to the rear license plate... I will remove the rust that is developing. What is great is that when the time comes to remove the 5 Second Fix it can be easily removed with an Xacto or utility knife.
    For many items I would suggest using mainly silicone, but with a few dabs of 5SF to hold it in place until the silicone cures. Of course that would not be necessary with caps that are soldered in place.
    I've been using that technique with hot melt glue and silicone with great results: about 2 years ago I added a hardwood threshold to the side door in my garage as there was a 3/4" gap that rats were crawling through. The floor was a smooth finished concrete and I didn't have the equipment to do it the right way but it hasn't budged. What the heck if it comes loose in a few years I'll just glue it down again...
    Right now I'm using the same trick to resecure some loose tiles in my shower stall.
    Steve Ahola
    Attached Thumbnails Attached Thumbnails 6c777856520342a0ae78f88a351cf1f7.jpg
  9. #9
    4,027
    Quote Originally Posted by tedmich View Post
    So how is "electronic grade silicone" different from the 100% silicone? Just wondering...
    Steve A.
    P.S. In the mid-80's I rewired my 1965 Pro Reverb with several different mods gleaned from various magazine articles; I used hot melt glue to secure items like a relay to the eyelet board. What a mess — I didn't want my soldering iron to get anywhere near that crap!
  10. #10
    "Thermionic Apocalypse" -JT nickb's Avatar
    Dec 2009
    Devon, UK
    2,523
    Quote Originally Posted by Steve A. View Post
    Steve A.
    It has a neutral ph while curing. And costs 10x the price.
    PS: Here's a nice article on curing https://www.intertronics.co.uk/articles/tb008.htm
  11. #11
    rjb
    rjb is offline
    Feb 2010
    Somewhere near Bawlmer, Merlin
    2,199
    I've read somewhere on MEF that GE Silicone II is safe for electronics.
    Can someone confirm or refute?
    -rb
  12. #12
    547
    I read somewhere that some types of silicone may become conductive over the time but I don't know how true is that.
  13. #13
    Oct 2015
    153
    i use a hot glue gun, they make a variety of sticks,
    it is quick as the glue sets up pretty fast,
    i offer a lifetime warranty on all my work so by the time the glue quits again i will be six feet under, only good thing about getting old that life time guarantee,
    when an amp is coupled to the speaker cab as in a combo, you will have standing waves rattling the pc board around. good engineers will test for this and bolt down the board accordingly you can tell when they have not engineered for this, the glue will be rattling around the box,
  14. #14
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    4,533
    Quote Originally Posted by rjb View Post
    -rb
    No science papers here, but I've been using GE "RTV" Silicones over 40 years with electronics of all sorts. Including circuits that needed 25 kV or more insulation. Rarely a problem. Sometimes it doesn't want to stick, and it is easy to shmear it where you don't want it to go. All in all good stuff, I always keep some on hand.
    rjb likes this.
  15. #15
    rjb
    rjb is offline
    Feb 2010
    2,199
    Quote Originally Posted by Gregg View Post
    Oh, my. By "safe for electronics", I was referring to non-corrosive cure. I never considered that silicone could become conductive. Are you referring to black silicone sealant that might contain carbon black?
    -rb
  16. #16
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,442
    Contact/Rubber cement works too. It can get brittle when decades old.
  17. #17
    547
    Unfortunately I don't remember the details.
  18. #18
    Supporting Member
    Dec 2009
    UK
    3,025
    I have some high-temperature silicone that contains carbon and even that doesn't become conductive under prolonged heat. The microscopic carbon particles are each effectively insulated by the silicone. Electrical conductivity could be an asset (just like conductive polymers) especially if it changed under pressure.
    Hot melt comes in numerous grades and some is appalling quality, so you can't generalize. I had some electronic disability aids to repair and the hot-melt used by the manufacturer was incredible - at the time I thought it may have been some military-grade product. And the worst I've seen in commercial amps is the pure white stuff used by Trace Elliot; comes off like candle wax and has no ability to stick to anything.
  19. #19
    Near Seattle, WA, USA
    662
    Regarding conductivity in silicone adhesive/sealer: I can say from personal experience it can happen if the stuff isn't fully cured before exposing it to voltage. Another tech backed this up with his own personal experience while we were sharing 'war stories' one day.
    Though I haven't tried it the yellow stuff used by some manufacturers reminds me a lot of 3M automotive weatherstrip adhesive, and/or possibly 'Shoe Goo'.
  20. #20
    rjb
    rjb is offline
    Feb 2010
    2,199
    Quote Originally Posted by Mick Bailey View Post
    Like use it to upgrade the carbon pile footswitch for a vintage sewing machine pickup winder?
    -rb
  21. #21
    Apr 2008
    Sonoma CA
    3,111
    Quote Originally Posted by Leo_Gnardo View Post
    No science papers here, but I've been using GE "RTV" Silicones over 40 years with electronics of all sorts... I always keep some on hand.
  22. #22
    Apr 2008
    Sonoma CA
    3,111
    Steve Ahola
    Some people do like this UV cure CA, but many online comments are that the dinky UV light fails to work/or work well. Luckily there are some good strong UV LEDs in online surplus like this
    HI-INTENSITY UV LAMP ASSEMBLY | All Electronics Corp.
    almost 20W for $6!
  23. #23
    Senior Member TimmyP1955's Avatar
    Mar 2007
    Indianapolis
    332
    E6000 might be good for caps (it's the stuff that folks use to glue the hammer tips onto Rhodes hammers).
  24. #24
    Supporting Member
    Feb 2007
    Seattle WA
    273
    Well I borrowed a glue gun from the 13 year old neighbor girl. She uses it for crafty girly type stuff (putting plastic flowers on lampshades and what not). The glue gun was even pink! I just needed a little dab to mount the large caps to the solid state bass amp. Tomorrow I am off to the craft store to buy my own glue gun. Gosh I hope they have more colors than pink!
    Mark Black likes this.
  25. #25
    rjb
    rjb is offline
    Feb 2010
    2,199
    Quote Originally Posted by Axtman View Post
    Don't worry, they also have blue.
    -rb
  26. #26
    29,180
    Me, I'd like one in the Hello Kitty motif.
    Justin Thomas and rjb like this.
  27. #27
    Supporting Member
    Feb 2007
    Seattle WA
    273
    Collect all four!
    Justin Thomas, rjb and g1 like this.
  1. CA Glue (Super Glue)
    By big_teee in forum Tools and Coil Winding Gear
    Last Post: 03-14-2015, 05:54 PM
  2. Anyone have a hot glue gun they like. What glue for what purpose?
    By David King in forum Tools and Coil Winding Gear
    Last Post: 10-26-2014, 11:28 PM
  3. Replies: 33
    Last Post: 03-10-2010, 07:33 PM
  4. What have YOU used to glue Tolex with?
    By nicksorenson in forum Build Your Amp
    Last Post: 08-30-2007, 06:31 PM
  5. Glue
    By kevinT in forum Pickup Makers
    Last Post: 02-13-2007, 10:28 PM
