Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Paully1
Thread: Heat Shrink
    Jun 2017
    Maine, U.S.A.
    5
    Heat Shrink
    Gonna be doing some wiring on my guitar.
    I'll be using 22 awg Cloth push back wire.
    What size shrink tube do I need?
    Thanks
    Jun 2006
    California, USA
    3,418
    Quote Originally Posted by Paully1 View Post
    ...What size shrink tube do I need?...
    Usually none. Tell us why you think you need heat shrink.
    Better Tone thru Mathematics bob p's Avatar
    Chicago, USA
    4,234
    I was going to post something similar, but I thought I was better off not saying anything.
    There is a school of thought among amp builders in which the ends of every wire get a little bit of HST to cover the end of the wire sheath and the solder connection, as if they're putting on a sock as a dress-up measure.
    I think that the practice started among new amp builders who ended up overheating their PVC wires and giving them nasty burn marks and created embarrassingly melted ends when soldering. I remember that years ago one fellow developed a novel solution to hiding his mistakes by sliding a small segment of HST up the wire prior to soldering. Then after he scorched black the ends of his PVC or his cloth wire, he'd slide the HST down over the solder joint to cover his mistake. He posted a bunch of photos of his amp build on one of the sites (amp garage?) and his build had these little HST socks everywhere. He must have had a hundred little socks on all of the connections.
    When I saw those photos I knew exactly what was going on -- somebody was trying to hide bad soldering technique by putting little condoms everywhere. It must have added a huge amount of time to the project. Although I saw it as a cover up solution to Band-Aid his bad soldering technique, the HST sock method was rapidly accepted by a large number of people. I guess lots of people have the problem of overheating their wires when soldering, and wanting to cover up the ugly remnants of the soldering process when they take pictures of their amp to show off online.
    Some people use Teflon wire to avoid the overheated insulation problem. Some just put HST over PVC and cloth wire. I prefer to just turn down the temp control on my soldering station. To me, the HST seems to be a hobbyist dress-up thing. I can't imagine any commercial builder wasting time like that.
    Jun 2017
    Maine, U.S.A.
    5
    The reason I'm thinking S.T. is that I have a couple of pick ups that only have approx. 1" of original lead.
    I want to extend the leads to a functional length and S.T. the splices.
    Thanks
    Chuck H likes this.
    May 2007
    pacific north west
    12,502
    That's one of only a few things I use hst for. But there ARE a few. Another is when a layout benefits from having a component lead as the only lead, but it's a high voltage connection. Yet another is when I'm making shielded cable leads. The exposed shield is often a very fine stranded copper and it's near impossible to have no strays when stripping. So in that regard it's cosmetic, but OTOH it also gives me peace of mind knowing that after some amount of vibration there's still no chance that a hair thin copper element will find it's way into contact with anything else. So I'm surprised that you had to defend your position since hst is a pretty regular part of everyone's arsenal.
    As to size... I dunno.?. I just get the stuff when I need it and eyeball the size based on how much I expect it to shrink. You could do the same. Radio Shack is kaput now I think, but there's still Fry's. You wouldn't want to order only one piece of hst anyway, so buy a "kit" and have it in your arsenal for many projects. It's good for more than electronics to be sure.
    "So I acquired it for the purpose of fixing it up - in case I run out of things to do with the rest of my life..." tubeswell
    "Shut up, you big dumb poopy-head!" Justin Thomas
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,162
    Typical shrink is to half diameter. I just look in my shrink tube bin and select tube that slips over the joint it protects. it will then shrink around it with no saggy spots.
    I sometimes use it as spaghetti on bare wires that cross, but largely I leave it for things outside an amp. Inside I do like it on the unterminated end of shielded cable. For similar reasons to Chuck's - stray ends.
  7. #7
    Chicago, USA
    4,234
    Spaghetti. You are an old timer.
    When I have a lead that I need to insulate (like chuck mentioned) I'll make my own spaghetti by using a wire stripper to pull a section of nice thick PVC off of an insulated wire, and slip that over the lead. That ends up being a lot thicker and more durable than HST. FWIW, I have an ancient one of those "Ideal" spring loaded wire stripper guns, where it grabs the wire, a blade comes down to make a cut, and another arm then grabs the insulator and pulls it off. Those strippers cut really nice spaghetti substitutes.
  8. #8
    29,162
    That is usually what I do, but once in a while I use shrink tube for one reason or another. My Paladin stripper does a good job of it.
  1. Solder Shrink Sleeve connectors?
    By tedmich in forum Music Electronics
    Last Post: 06-20-2016, 08:16 PM
  2. Favorite heat shrink heating tool for small and tight spaces?
    By mike_mccue in forum Music Electronics
    Last Post: 08-08-2014, 11:52 PM
  3. Heat Shrink size for AWG 28 x2
    By Stratz in forum Pickup Makers
    Last Post: 04-15-2013, 04:21 PM
  4. Cable-end heat shrink?
    By Rhodesplyr in forum Music Electronics
    Last Post: 03-25-2011, 02:31 AM
  5. Great Source for Heat Shrink Tubing
    By kevinT in forum Pickup Makers
    Last Post: 09-28-2009, 04:13 PM
Tags for this Thread
