Results 1 to 11 of 11
Like Tree4Likes
  • 2 Post By The Dude
  • 1 Post By Axtman
  • 1 Post By Axtman
Thread: Bassman 10 OT
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    5,367
    Bassman 10 OT
    I've got a Bassman Ten with a bad output transformer. Of course, I can cobble lots of things in there, but I'm wondering if anyone knows of a drop in replacement with the same footprint. I haven't spotted anything so far. The number on the part is 021848A. Here's a pic.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,399
    I have a Bassman OT that sits the other way - long direction horizontal. 022871
    I have an OT for a HR DeVille 018343
    Either should work, neither would drop right in.
    May 2010
    Sioux Falls, SD
    5,367
    I believe the 022871 is for a 4 ohm load? Not sure about the 018343. Does it have multiple taps? I need an 8 ohm secondary. Can you confirm if either of yours is 8? I'm not having any luck finding a drop in, so I might be interested in one of yours if there is an 8 ohm tap on either. Thanks Enzo!
    g1
    g1 is offline
    Feb 2010
    9,852
    The 022871 is 4 ohm.
    Have you looked at classictone? They have several for bassman but with switchable impedance.
    Certified Dotard
    g1
    g1 is offline
    Feb 2010
    9,852
    The 018343 has 2,4, & 8 taps.
    3&1/4 x 2 inch centers.
    edit: another source lists 3&1/2 x 2 inch so not sure which is correct.
    Certified Dotard
    May 2010
    Sioux Falls, SD
    5,367
    I did look at Classic Tone and was leaning that way, but I figure if I can help Enzo get rid of some inventory and make him a few bucks, why not? I didn't see anything on their site with the same footprint. Good to know on the 018343 (multiple taps) and thanks for the info. No matter what, I'm probably going to have to drill the chassis for a different part, so I don't care much about mounting.
    g1 and nosaj like this.
  7. #7
    30,399
    Says 2/4/8 in the docs. Can't say dimensions until I unearth it in my storage unit.
  8. #8
    May 2010
    Sioux Falls, SD
    5,367
    I PM'd you.
  9. #9
    Supporting Member
    Feb 2007
    Seattle WA
    307
    The Dude likes this.
  10. #10
    Better Tone thru Mathematics bob p's Avatar
    Chicago, USA
    5,216
    Dude, my Bassman 10 has it's original Schumaker iron. The stampings are 021848-1 and 606-3-27. As you noted, it's spec'd for an 8R load. the Bassman 10 used four 32-ohm speakers in parallel.
    Nobody is making a proper replacement OT for a Bassman 10 (other than Mercury). Everyone else seems to think that the Bassman 10 is a 50W amp, so everyone tries to shoehorn 50W iron into a 40W amp -- what a surprise, it doesn't fit. If you want something that's 8R you can probably get away with using a multi-tap universal OT that has 2/4/8 or 4/8/16 taps, but you'll have to shoehorn 50W iron to make it fit.
    FWIW my Bassman 10 dates to 1974 and at that time Fender was using Bandmaster / Super chassis and PT iron for a lot of their 40W applications. My Bassman 10 has all of the holes drilled into it for all of the reverb / tremolo controls, as well as all of the mounting holes for the various sizes of OT that the different 40W amps used. that way they just used one chassis and populated it with whatever they needed. It's not set up for the larger 50W iron because it is after all, a 40W amp.
    If you want something authentic that has the right footprint, I hate to say it, but Mercury might be your only option. Damn ... I can't believe I said that.
  11. #11
    Supporting Member
    Feb 2007
    Seattle WA
    307
    Tube Amp Doctor makes an exact replacement. See the link above in my previous post.
    Most other replacements have multiple outputs (2, 4, 8, 16 ohm). TAD transformer only has an 8 ohm tap just like the original. The TAD replacement transformer was such a exact match that I took the old bell housings off the old fried original transformer and installed them on the new transformer. I used the original mounting holes and did not have to drill new mounting holes. Nobody but you and me will know that the output transformer is not original.
    The only downside is that you have to order the transformer from Germany.
    Jazz P Bass likes this.
  1. Bassman 10 -- Where's the Love?
    By bob p in forum Vintage Amps
    Last Post: 07-22-2016, 02:00 AM
  2. Blackfacing a 74' Bassman 10
    By tibbar6 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-10-2016, 03:37 PM
  3. farty bass problem, Bassman 10
    By otto pärt in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-25-2009, 06:32 PM
  4. Fender Bassman 10 Question
    By MicroMack in forum Vintage Amps
    Last Post: 01-28-2008, 09:27 PM
  5. Fender Bassman 10 project
    By Blindog in forum Mods & Tweaks
    Last Post: 10-08-2006, 03:49 PM
