Results 1 to 22 of 22
Thread: 1965 Supro
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    1965 Supro
    What tube goes in socket between the 3 12AX7 sockets ? Directly under the foot switch and intensity.
    Bottom tubes are 6L6GC, 6L6GC, and 5UA
    It is a 1965 Supro with a 15 in. speaker.
    I have yet to find a useful schematic.
    NEVER MIND ... Figured it out ... duhhh: rolleyes:
    Thanks
    Doc
    Senior Member nevetslab's Avatar
    Apr 2010
    Burbank, CA
    574
    The only Supro Amp I've worked on was the Thunderbolt, which we still have in our rental inventory. After replacing a bad pair of 5881 power tubes, I found the amp was really noisy, and had plenty of gain. I ended up swapping out the input preamp tubes (12AX7) with a 12AY7, which calmed it down, still with plenty of gain. Input jacks on it were not grounding-types, so the amp would hum/buzz if nothing was plugged in and the volume turned up.
    Supporting Member mozz's Avatar
    Oct 2015
    NEPA
    435
    The model number may be painted on the wood by the lower chassis.
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    There is a small silver label with the numbers 1-22738 What is that ?
    There is NO volume, hum, or hiss and the speaker and speaker wires are OK
    Could bad main filters cause this ? There is also a large single filter under the bottom chassis which is bulged at both ends.
    Just wonder what caps to check and if caps can cause absolutely NO volume ?
    Doc
    Oct 2015
    NEPA
    435
    The silver tag is the serial number. If you keep plugging it in and there are problems, you may burn out the transformer. You won't find another. Filter caps, especially if they are bulging, need to be changed. Pull all the tubes and measure the HV.
    Apr 2010
    Burbank, CA
    574
    In looking at the right photo, I'd guess the 12AX7 at the far left is your input tube, then next to it is the rest of the preamp stages, and teh tube on the other side if the I/O power supply connector is the driver tube for the power amp/power supply sitting down in the floor of the cabinet. What skill level are you? I see you've been posting on the forum quite a bit, so I assume you are technically skilled. Are you set up with a test bench and basic instruments.....multimeter, signal generator, scope, variac, etc? Do you have heater glow on the tubes when it's powered up? (both up in the preamp/driver stage above and below in the power amp/power supply? Do you have the means of measuring AC mains current/wattage, like thru a metered variac?
  7. #7
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    Quote Originally Posted by nevetslab View Post
    You are correct on the far left tube being the input. My skill level ... I have bought, repaired and sold around 20+ tube amps ( mostly Fender, Marshall, Silvertone ) I use a Multimeter, and Variac. Test bench with basic items, but no signal generator or metered variac. All tubes glow, preamp and power amp.
  8. #8
    Apr 2010
    Burbank, CA
    574
    With the speaker disconnected, (1 terminal open is fine), do you get 'nominal' DCR on the voice coil. Around 6 ohms if it's an 8 om speaker.
    Assuming yes to that, we can deduce a number of things already. The I/O cable that plugs into the socket from the power amp/power supply carries heater voltage successfully, two wires (at least) carrying one side of the AC mains to the on/off switch. Beyond that we'd have to begin probing. I'm always a big fan of close inspection of the wiring of connectors like that. We don't yet know if the plate voltage to run the preamp and driver tubes is present. There may be just one DCV line, and it gets further filtered and dropped down from the one level up in the preamp chassis, as the driver tube susually runs on somewhat higher voltage than the preamp tubes do. There would be a pair of signal leads, no doubt twisted that come from the driver tube (push-pull to the power tubes), probably AC coupled, though no guarantee on that. And, there would be at last one ground wire.
    Do all the connections into the mating plug appear to be solid? The other end probably goes thru a rubber grommet or strain relief, and into teh back end of the chassis down below.
    We'll need to know that you have the plate voltage supply present up in the preamp chassis. I'm guessing the plates on the power tubes to be around 400VDC, and the plate voltage on the driver tube to be around 3--=350V, where the plate resistors connect. The plate voltage on the tube itelf will be much lower, lke around 180VDC. The Preamp tubes will be running at around 250V-300V where the plates connect, and supply voltages at the plates in the 150V area.
    Let's see what you find up to this point.
    What is the Tube Rectifier type? 5UA is not correct. 5U4 or 5U4BG would be, though physically, that looks more like a 5AR4 in size.
  9. #9
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    Thanks nevetslab
    Rectifier is 5U4 ... I'll start getting the info tomorrow.
  10. #10
    Oct 2015
    NEPA
    435
    Doesn't look like a 5u4 in the picture. Have you measured the HV yet?
  11. #11
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    hey mozz ... you have a good eye my friend ! ... actually that was an old picture with a 5Y3
    Will check the HV soon
    2 heads are better that one, especially when one is mine
  12. #12
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    7.3 on the voice coil ... tried speaker on other amp and it sounds great ( lower volumes )
  13. #13
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    Wires all tight and connections into mating plug seem solid.
    Inside the 8 pin plug from power supply chassis, my readings show several wires are connected ... I am assuming this is correct ?
    Plates on power tubes is 490v
    Preamp plate pin 1 is 423v
    Preamp plate pin 6 is 202v
    As I was checking pin 1 on preamp tube
    1 ... bottom of multicap capacitor started smoking
    2 ... then I heard a pop and saw the 450v cap had ruptured the + side
    The amp was on for about one minute when this happened.
  14. #14
    Apr 2010
    Burbank, CA
    574
    Well, we were sort of suspecting that power supply cap to be dodgy, based on the physical description early in this thread. Prior to the multi-section filter cap blowing, you were reading 423VDC on Pin 1 of one of the 12AX7's. That's much too high, but may be a result of a decoupling resistor having failed as well. Is there just one high voltage wire coming up from the power amp/power supply chassis down below? The voltage on Pin 6 seemed reasonable.
    Otheres here on the forum have alternate sources for multi-section filter caps. I've usually been buying them thru Antique Electronics Supply in Arizona. when I need them. Staying witing that mechanical format makes them expensive. I've often changed the mechanical packaging to allow better quality radial or axial leaded single-section power supply caps, of where there are a number of sources. You'll have to assess that when you open up the power amp/supply chassis.
    You'll need to assess the damage in the power amp/supply chassis for other parts besides the multi-cap. Once a solution is decided and parts are on order, you can still move forwards from there, to see where you've lost signal.
    While I have the luxury of fine lab power supplies, allowing me to power up sections of an amp that I'm working on, after disconnecting the section that has gone down, awaiting parts, I can still make forward progress to see how the front end is working. If you're careful, you can also do this with another working tube amp that's similar enough. It's a whole lot easier with known accurate schematics of both units, so you can marry the front end of one, and substitute it for the front end of a different amp, allowing you to see what else needs attention I'd only do this if I had 100% confidence in what I"m doing.
    At any rate, forward progress being made, in spite parts failure. That's to be expected.
  15. #15
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
  16. #16
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    I do not know if there is only one HV wire going up from power chassis as there is only the 8 pin coupling plug. Do I need to test all pins of that plug with amp on ? Tubes out or in for test. If so, when ? Now or after I have replaced the multi cap can and the power filter cap ?
    I have rebuilt a multi cap can on a Vibro Champ, so I am sure I could do that on this amp but would rather just buy a new cap can from Tubes and More. They have a 450v 20, 10, 10, 10 for $36 bucks. I'll order the parts and resume the testing.
    I have a 64 Deluxe Reverb that I replaced all caps and resistors on, the Vibro Champ ( cap can rebuild ) and a Champ. I am not to sure about "marring" 2 amps for test purposes. Good idea, though. Time is on my side and I am in no hurry on this Supro. Without a schematic/layout it'll get done when it gets done.
  17. #17
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    4,702
    It shouldn't be too hard to trace out that connector and see what's going on.
    (Guessing) There will be a couple of filament wires, probably 2 wires for the power switch, ground, B+, signal feeding amp. That's 7 pins. Maybe another ground? Maybe one pin is unused. Maybe I forgot something. At any rate, the connections should be fairly obvious. Draw yourself a little diagram and get to labeling.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  18. #18
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    Is 475v multi cap instead of 450v good enough ?
  19. #19
    May 2010
    Sioux Falls, SD
    4,702
    Yes. In that case more is better.
  20. #20
    Apr 2010
    Burbank, CA
    574
    From the new photos you've posted, we can see there are only six wires on the Octal plug cable, being 2 wires for the heaters, 2 wires for the AC Mains switch, Ground and V+ to run the preamp tubes. The push-pull wires for the power tubes can be seen (Brn/Wht and Red) running to the right-most connector attached behind the octal socket on the amp chassis. Not sure what the left 2-pin connector is. If you don't have a signal cable from the preamp plugged into that right connector, that's why there's no signal.
    Looking at the power tube socket wiring, I see the heater wiring using Blue and Blu-Wht on pins 2 & 7. Pin 8 is tied together with teh Grn wire, and has a 220 ohm power resistor connected to Gnd, so this is a Cathode-biased output stage. I see Brn and Blu cloth-covered wires from the primary of the Output Xfm primary, and the left tube socket uses pin 1 as a tie pint for the Center-tap of the O/T Center-tap. It comes from the rectifier tube at pin 8, with the 1st stage filter for this by way of the blue wire connected to the cap can. Then, we see a 350 ohm power resistor from that filter stage to the axial leaded power supply filter, having a date code of 6518. That dates this part as 18th week of 1965. So, you'll want to replace that cap as well as the plastic bodied Mallory electrolytic caps up in the preamp, and any other electrolytic caps we're not seeing. You'll see similar date code on the cap can, and I'd guess the amp was manufactured in mid-late 1965, maybe 1966.
    Not sure where the screens tie in..I do see them tied with an orange wire on pins 4, with a YEL wire that disappears under that axial power supply cap.
    On the replacement caps, the lower voltage parts (probably cathode bypass), you can go with higher voltage ratings with similar capacitance values, as today's caps are much smaller, and the higher voltage raging parts are more linear/better. With the power supply filters, same or higher voltage ratings.
    Where you had a plate voltage above 420VDC, I'd look at the decoupling resistors in the power supply filter string, or perhaps the plate resistor on that stage, as that voltage is too high.
    So, we now know a lot more than we did. Forward progress.
  21. #21
    Jun 2007
    4,960
    I'd also check to see what the voltage at pin 3 is on that tube. The high plate voltage could also be sign that the tube is not conducting.
  22. #22
    Supporting Member
    Jan 2009
    Santa Cruz, Calif.
    260
    Thanks for all the helpful details.
    Just ordered all parts from AES
    I'll do what I can 'til parts arrive.
    Doc
  1. 1965 blackface deluxe reverb
    By mikep in forum Guitar Amps
    Last Post: 01-26-2017, 08:32 AM
  2. Looking for 1965 Supro Handle Replacemnet
    By Tom Phillips in forum Repair and Restoration
    Last Post: 01-16-2017, 06:20 PM
  3. 1965 Precision rewind
    By StarryNight in forum Pickup Makers
    Last Post: 10-08-2015, 09:21 AM
  4. 1965 Supro Amp
    By Doc Stitches in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-08-2015, 02:43 PM
  5. 1965 SUNN Amp?
    By Jenkster in forum SUNN
    Last Post: 02-14-2008, 05:34 AM
