Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By eschertron
  • 1 Post By Djoksi
Thread: EMG 81 and 85 wiring diagram,what si wrong?
    Jan 2018
    3
    I bay EMG 81 and 85 pickup and,when wiring on this scematics
    https://tops-stars.com/wp-content/up...ng-diagram.jpg
    Both pots are master volume but i want one volume ad one tone pots.
    Whats is wrong with this diagram?
    Thanks
    Aug 2012
    Great Black Swamp
    1,714
    emg-81-85-wiring-diagram
    verify that the tone cap is an acceptable value (small enough to roll off only high frequencies) and that there is no short between the tone pot wiper and ground. If there is a short, the tone control will function like another master volume.
    Mick Bailey likes this.
    If it still won't get loud enough, it's probably broken.
    We need more chaos in music, in art... I'm here to make it.
    Supporting Member
    Dec 2009
    UK
    3,136
    The diagram is fine.
    Also, make sure the capacitor lead is not shorting against the pot casing. If you could post a picture of your guitar wiring it would be helpful.
    Jan 2018
    3
    Quote Originally Posted by eschertron View Post
    Pots is both 25k...But i understand,what do you mean (that there is no short between the tone pot wiper and ground. If there is a short, the tone control will function like another master volume)?
    Aug 2012
    Great Black Swamp
    1,714
    Quote Originally Posted by Djoksi View Post
    If you have a wire (short, continuity) from the pot to ground, as you turn the pot down ALL frequencies are shunted to ground. The volume drops. On the tone control, the cap between the pot and ground selectively shunts only high frequencies to ground. If this cap is incorrectly sized or missing (a straight wire in its place, i.e., a short) then the tone control will act as a volume control. This is the behaviour that you describe.
    Check all the soldering and wiring in the control cavity. Photos will help. Do you have a meter? Check continuity from pot connections to ground. draw a picture and mark the resistance readings.
    Jan 2018
    3
    Thank you people, I found a problem.
    Capacitor lead touching housing pots and pots conections
    Thanks all....
    eschertron likes this.
  1. Replies: 8
    Last Post: 11-15-2014, 07:56 PM
  2. 81 Music Man Repair - 6L6 Installed Wrong
    By Jtwusmc in forum Guitar Amps
    Last Post: 02-25-2013, 11:43 PM
  3. Is there anything wrong with this wiring diagram?
    By TRadja in forum Guitar Tech
    Last Post: 08-31-2012, 05:39 AM
  4. Replies: 1
    Last Post: 06-27-2012, 03:47 AM
  5. EMG 81 / 85 Preamp Burning
    By rdndnr in forum Pickup Makers
    Last Post: 05-21-2010, 07:31 PM
