Results 1 to 7 of 7
Thread: Broken EDC SR-99 drum machine
    Dec 2017
    United Kingdom
    14
    Hi.
    Flushed with success from my boss dr-55 fix (see other thread), I decided to have a go at my broken EDC SR-99 drum machine.
    This is different to both the dr-55 and sr-88 machines, so the schematics aren't that much use. (the '99 is more complex)
    The problem is that I can't get the damned thing to go into 'pattern write' mode. It stays in "play" mode, and the start/stop buttons just do exactly that, not program sounds.
    I have replaced the 4011 (although it's socketed and the socket may be dodgy -someone else did that..) and also the TC5514 memory chip. No luck.
    I cannot find a schematic or service manual for the sr-99 anywhere.. can anyone help, or point me in the right direction?
    Thanks.
    Dec 2017
    United Kingdom
    14
    Here's a link to my blog about this project: https://synteknik.com/projects/curre...sr-99-project/
    g1
    g1 is offline
    Feb 2010
    9,321
    Where do the sounds come from and why are they not there? When the unit was brand new you could play sounds without programming couldn't you?
    Certified Dotard
    Dec 2017
    United Kingdom
    14
    The patterns are stored in the SRAM chip. They get wiped if the battery is disconnected, and/or you replace the chip, which I have.
    g1
    g1 is offline
    Feb 2010
    9,321
    Sorry, I misunderstood and thought you meant it doesn't play or write.
    So it will play the factory sounds, but won't go into 'pattern write' mode?
    Certified Dotard
    Dec 2017
    United Kingdom
    14
    That seems to be the problem, yes.
    Sorry about the delay, I got distracted by another shiny project (Hohner EK 2)
  7. #7
    g1
    g1 is offline
    Feb 2010
    9,321
    Attached is a 5514 datasheet. Check for any action on the read/write pin when you activate pattern write button (and I hope you have verified the button switch).
    If no action on the R/W pin, trace back from it and see where it is getting that command from.
    I don't have high hopes for this unit without a schematic.
    Certified Dotard
  1. Need advice fixing Boss Dr.55 drum machine
    By methodofcontrol in forum Music Electronics
    Last Post: 01-18-2018, 11:20 AM
  2. Custom drum machine rack photos
    By captainlee in forum Music Electronics
    Last Post: 04-30-2010, 05:23 AM
  3. Korg SR-120 Rhythm Machine Schematic.....
    By jrfrond in forum Schematic Requests
    Last Post: 08-08-2009, 01:56 AM
  4. Computer drum machine???
    By Satamax in forum Fun with computers
    Last Post: 06-05-2008, 11:48 PM
  5. a good drum machine?
    By MarkXXX in forum Fun with computers
    Last Post: 03-15-2007, 12:58 PM
Tags for this Thread
