Results 1 to 4 of 4
Thread: Dearmond Silver foil pickup - Rivets
    Junior Member timdaalman's Avatar
    Apr 2018
    Netherlands
    8
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Hello guys,
    I would like your help if it is possible.
    I have a Dearmond Silver Foil pickup original 1961 and I want to rewind because it's dead but the problem that I have is where can I find the two rivets that hold the cover to the bottom.
Name:	Photo 25-4-18, 2 34 37 μμ.jpg
ID:	48625Click image for larger version.
Name:	Photo 25-4-18, 2 34 48 μμ.jpg
    I must break them to open it but do you know someone what size they are and from where I can buy them in USA?
    Thank you in advance for your help!
    Best,
    Tim
    0 Not allowed! Not allowed!
    Supporting Member
    PDX
    3,212
    Thumbs Up/Down
    Received: 3/0
    Given: 0/0
    Once you get them apart by drilling the backs off you can measure them and we'll help you track down the replacements. These particular ones are called mushroom heads and they come in all diameters and lengths. They are usually very low carbon steel like 1005 to be malleable.
    Apr 2018
    Netherlands
    8
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Thank you David. I will try to find a store that will have them in different sizes.
    Supporting Member
    PDX
    3,212
    Thumbs Up/Down
    Received: 3/0
    Given: 0/0
    Try Mcmaster.com What you want is a hollow-end rivet aka semi-tubular rivet;
    https://www.mcmaster.com/#semi-tubular-rivets/=1cmjc78
    The diameter is easy, the length is from the back of the head to the bottom of the hole. You'll need the tool that mushrooms the back.
  1. Dearmond Gold Foil Info & Rewinding
    By jrdamien in forum Pickup Makers
    Last Post: 02-11-2015, 11:11 PM
  2. dearmond silver foil pickup help for rescue! reposted from gtr tech forum.
    By dboonelee in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-04-2014, 08:01 PM
  3. dearmond silver foil pickup help for rescue!
    By dboonelee in forum Guitar Tech
    Last Post: 09-27-2014, 11:43 PM
  4. Dearmond Gold Foil Pickup Specs
    By bensimonmusic in forum Music Electronics
    Last Post: 04-08-2011, 08:56 PM
  5. Specs or guidelines for DeArmond gold foil
    By GlennW in forum Pickup Makers
    Last Post: 11-30-2006, 04:32 AM
