Go Back   Music Electronics Forum > Amplification > Other Amps
Old 08-29-2006, 07:50 PM   #1
Microphone preamp ?
Does anyone know of schematics for a nice tube-based microphone
preamp ? Preferably 2 channels with phantom power.
I've found this one so far :
http://www.tangible-technology.com/tubes/1566/1566.html
Any comments as to the suitability of running microphones through
tubes would also be appreciated.
Paul
Paul P is offline   Reply With Quote
Old 08-29-2006, 08:46 PM   #2
Paul
Not a schematic, but Hamptone sells this kit:
http://www.hamptone.com/HVTP2.htm
steve
steve is offline   Reply With Quote
Old 08-29-2006, 10:44 PM   #3
http://www.frontiernet.net/~jff/pult...MB1_proto.html
markbul is offline   Reply With Quote
Old 08-30-2006, 03:26 AM   #4
Here are a bunch of them:
http://www.waltzingbear.com/Schematics/Schematics.html
Old 08-30-2006, 09:04 PM   #5
Thanks for the links, lots of interesting stuff to read. I've found many
solid state circuits, which look easy enough to build, but not that many
tube circuits. The Pulteq is more or less what I was looking for, a simple
tube circuit to study.
I just found the following, which looks like it would be hard to beat. A
tube mic preamp (with ss power supply) that meets all my requirements :
http://www.gyraf.dk/gy_pd/g9/g9pd.htm
except that it uses European parts which might be a slight inconvenience,
my living in North America...
This should keep me busy for a while.
Paul
Old 08-30-2006, 10:20 PM   #6
Amp Kat's Avatar
Go to the jensen transformer website and check those out. One thing is if you build them go as close to the specs as you can. Whatever mic pre you build use an input transformer. The Cascodes are very nice.
__________________
KB
Amp Kat is offline   Reply With Quote
preamp tube wiring tubefan Build Your Amp 4 08-28-2006 03:47 PM
weak preamp overdrive on 2555 silver jubilee mocklah Maintenance, Troubleshooting & Repair 35 07-18-2006 08:43 PM
Reconfigure Phono preamp for other use ... Todd Hepler Other Amps 3 06-10-2006 06:28 PM
