Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 03-19-2008, 03:14 PM   #1
preamp schematic help
Hello, I've been trying for weeks to simulate a preamp circuit found on R G Keens' page; geofex.com. It consists of two LC filters that cause a peak or a notch in the frequency response of the input signal (peak/notch depends on where you set the potentiometer - see attached multisim screenshot) at frequencies determined by the L, R & C values chosen in the LC filter sections.
However, when i simulate the circuit it only increases the gain of the whole signal across its' whole frequency response - as opposed to being frequency specific! Grr!
If anyone out there is willing to take a look at my schemtic and point out any errors I'd really appreciate it!
Thanks.
jenks is offline   Reply With Quote
Old 03-19-2008, 04:33 PM   #2
Well, 500uF and 1mF are incredibly large capacitors to be using in a solid-state filter circuit like this one.
I would expect maybe .5uF or 5uF but not 500uF!
How did you come about using those values? Can you post a link to the original RG schematic? That would help alot.
cbarrow7625 is offline   Reply With Quote
Old 03-19-2008, 04:44 PM   #3
Hi C barrow, no values were quoted for the R, L and C's in the Lc filter section. i just put in values in order to get the circuit affecting audible frequencies. I'll try changing those to see if it makes a difference... here's the link btw. You'll have to scroll down...
http://www.geofex.com/article_folders/eqs/paramet.htm
Cheers, Jenks.
Old 03-19-2008, 04:55 PM   #4
Thanks. OK, hopefully this will help you....For a passive notch filter like this one, a small capacitor & larger inductor will give you a higher "Q". A higher "Q" basically means that you are targeting in on a narrower frequency band than with a wide "Q" (see RG's notes on "Q" in the section above the one you cited for good graphic representations of this).
Using a VERY LARGE 500uF capacitor, what you have done is create a VERY LOW "Q" circuit. VERY low Q = affects all frequencies, not just the one you want.
Try dividing your capacitor values by 100 (5uF) and multiplying your inductor values by 100. THis should give you the same center frequency but a much higher "Q". The series resistor will also reduce the Q but in a different way. Any time I use a notch filter like these I always try it without a series resistor in place. THat way I get to see exactly what the Q ofthe filter is and how deep a notch it is making.
Once you are happy with your component values, then start adding resistance back in to tame the depth of the notch.
RG gave you the formula to calculate the needed values as well: The resonant frequency may be calculated as Fr=1/(2*pi*SQRT(L*C)). That along with my hint about how the cap size affects this equation should help you zone in on the proper values pretty quickly.
Let me know what you find.
Old 03-19-2008, 05:56 PM   #5
Thanks for all your help C!
I can't believe my circuit was working the whole time! It's just that the values chosen were so inappropriate that I was looking at gain at a set frequency but with too large a Q, so that on the bode plot it didn't seem frequency specific at all!
thanks again!
PS I may be in touch in very soon with more problems as you clearly know what you are talking about in these matters!
Jenks.
Old 03-19-2008, 08:10 PM   #6
Gyrator
Hi C,
I've been trying to get the gyrator that R G has added to work onto my circuit for last couple of hours unto no avail!
From looking at the math on R G's geofx page I think a ridiculously low capacitance is required at C2 & C4. I calculated that the capacitance needed to be around 5 x 10^-12 (femto!) farad. Did i get this right? If so then I need to think of a way of getting such low a capacitance! If not then I must have wired something wrong, but what (?) - I'm not exactly sure!
Anyway, any advice you have on the matter will be hugely appreciated.
Old 03-19-2008, 10:47 PM   #7
C2 & C4 on your sketch should really be pretty large! The input & output caps of the cirucuit are supposed to pass the signal without any low end rolloff. I would expect to see something from 2-22uF inthose places.
Try just putting a 22uF in your simulation. I think that should work.
Make sure to rember all of your zeros & decimal places when calculating values & frequencies.
Old 03-19-2008, 11:23 PM   #8
I've tried those values but it still doesn't work! hmm... Not at all sure why
bass preamp ubernerdsteve Guitar Amps 2 09-08-2007 09:11 PM
Amp Tubes / Using Preamp out silentbry Maintenance, Troubleshooting & Repair 11 02-10-2007 05:33 PM
Tube Mic Preamp Schematic Daver Music Electronics 9 01-19-2007 03:54 PM
ADA preamp brewu22 Maintenance, Troubleshooting & Repair 1 11-18-2006 07:03 PM
Microphone preamp ? Paul P Other Amps 5 08-30-2006 10:20 PM
