| | #1 |
| Member Join Date: Jun 2006
| twin reverb problems
My '73 silverface twin reverb has no reverb. Tried new cables tubes etc. I do get the crashing sound when I bump the reverb unit but thats all. How do I check the pan to make shure thats not the problem. It did work when I got it but just failed some time without notice. I checked voltages on the preamp tubes and they are all very high when checked against the AA270 schematic. I know thats not the right one but shouldn't it be a little closer than about 40v to 60v high at the plates? I suspect that the dropping resistors have drifted. I would like to fix this problem and blaceface the reverb channel. Which schematic is the best one to follow? After that I'm going to experiement with the normal channel. First things first, what would be the first thing to check? |
| | #2 | ||
| Lifetime Member Join Date: Jun 2006 Location: Connecticut
| Quote:
Quote:
Ray | ||
| | #3 |
| Senior Member Join Date: Jun 2006 Location: California, USA
| Why 47k Plate Resistors?
Ray, This is the first I remember hearing about using 47k PI plate resistors in the AB763 circuit. I never thought of trying that and always just change them out to 100k & 82k when I do a BF conversion. Can you explain what you like about the 47k set up? Thanks, Tom |
| | #4 |
Tom, I've always liked 12AT7 PI/drivers in Fender amps, and I feel the 47K Rp's are a better match to this tube than the 82K/100K '12AX7 PI' values if you're looking for clean headroom - and if you're not, IMO you're better off using a 12AX7 PI with the TR AB763 values; just my $.02. Ray |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Any thoughts on a UL Twin? | dave////irongater | Theory & Design | 7 | 08-28-2006 05:32 AM |
| Pot Problems | escyrs2000 | Guitar Tech | 4 | 08-17-2006 03:10 PM |
| Reverb mods for '70's Super Reverb | Steve A. | Mods & Tweeks | 5 | 07-22-2006 12:22 PM |
| Super Twin distortion? | drewl | Maintenance, Troubleshooting & Repair | 3 | 07-11-2006 04:22 AM |
| Slight problem with my Fender Twin Reverb. | Humbucker | Vintage Amps | 2 | 06-13-2006 03:03 AM |
