| | #1 |
| Senior Member Join Date: Nov 2007 Location: Columbia, SC
| replacing power cord strain relief
Im trying to replace the power cord on an amp of mine, but I cannot solve this strain relief. Never done this before, and Im tuggin and pullin but no luck. any help?
| | #2 |
| Senior Member Join Date: Sep 2007 Location: Indialantic, Florida
If it's the common Richco brown strain relief type, I usually use a pair of regular pliers and grab the devil outside the chassis, squeeze it enough to work it free. It buggers it up slightly but does not destroy it, in case you want to use it over again. Gary |
| | #3 |
| Junior Member Join Date: Oct 2007
You can do it with a set of pliers but the correct tool to use is a Heyco strain relief tool. They show up on ebay once in a while used and sell for about $30.00. Or you can get a new one here: http://www.etool.ca/RENDER/1/26/220/11113.html |
| | #4 |
| Senior Member Join Date: Jul 2006
They have a lip I find squeezing with right angle pliers on the inside works failing that cut the cable close as possible on the inside strip the sheath on the outside and pull individual wires through that should loosen it if that fails scream and drill the bugger out..if its this sorta clamp:- |
| | #5 |
The whole point of a strain relief is that when you tug on the wires, they don't pull out. Spread a pair of combination pliers and grip the thing, squeezing the small part down on teh wire harder. As you do so, pull the whole thing out. I often will rock it to one side to start. Get one side free and the other comes out easier. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Hammond Organ M- 101, power cord is snipped | David Eugene | Music Electronics | 11 | 04-25-2008 06:29 PM |
| Ampeg grounded power cord mod | bware | Vintage Amps | 8 | 03-26-2008 05:15 PM |
| Replacing Transformers? | BobbyBizzle | Mods & Tweeks | 3 | 09-01-2007 03:10 AM |
| Just installed a 3 wire cord and now there's a huge hum... Ampeg V4 | Iplayloud | Maintenance, Troubleshooting & Repair | 2 | 02-19-2007 11:35 PM |
| Replacing 6N7 with 6SL7? | Shark_Sandwich | Theory & Design | 4 | 01-21-2007 05:53 PM |
