Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Kit Amps
Old 11-02-2008, 03:15 AM   #1
Best recording amp
What small wattage kit amp would make a good amp for recording?
Going for vintage blues sound.
rymac is offline   Reply With Quote
Old 11-02-2008, 07:10 AM   #2
Hands down the 5f1 Fender Champ clones are probably the most popular kit build for low wattage blues/rock recording amps.
But that means NOTHING. You should find the tone you want and build that. Because if the 5f1 doesn't inspire you, your expression and playing will suffer. And that doesn't sound good.
Chuck
Chuck H is offline   Reply With Quote
Old 11-02-2008, 07:40 AM   #3
Supporting Member
+1 for a little single ended 1W-5W champy thing.
Or a low powered push-pull amp with vol, tone and trem controls in the same power ballpark with maybe a pair of 6K6s at a low voltage pushing an old 10W alnico speaker or a celestion blue or something
__________________
Old 11-02-2008, 08:51 AM   #4
Supporting Member
Steve A.'s Avatar
For modern amps the Epiphone Galaxie 10 has a pretty slick design, with a single 6V6 and a single 12AX7. It has a TMB tone stack but for a more tweed-like sound I added a "Texas Tea" control that passes the tone stack with a 2M pot and a .001uf cap:
http://www.blueguitar.org/new/schem/...galaxie_10.jpg
Just my 2 centavos...
Steve Ahola
P.S. I put a KT66 in mine which brings the power up to maybe 12 watts, I dunno... Cool little amp for small gigs!
Steve A. is offline   Reply With Quote
Old 05-08-2009, 04:42 PM   #5
"Best" is pretty subjective and depends upon your goals & taste.
I have a small battery of Fender vintage amps from a Vibro Champ up to a Pro Reverb and do occasional session recording. I like to get sweet Fender cleans on demand, and get a good distortion from pedals. The amp I use the most is the Vibro Champ. Put a good recording mic on it, set the volume around 4 or where ever is needed prior to any serious break up with the guitar and it will sound huge tonally on a recording. But that just suits my musical taste.
I have not tried the Tweed Champ. I'll bet is sounds awesome as well, especially if you're looking for pure class A grind.
mbratch is offline   Reply With Quote
Old 05-08-2009, 06:07 PM   #6
Supporting Member
I love my Lexicon Signature 284 for recording. If you are building from scratch, the schematic has most of the circuits you'd want for recording, so you can pick what you want and go for it. Stereo, great EQ section, cabinet sim, FX loop, balanced out, slave out, SE EL84. About the only thing it doesn't do exceptionally well is a clean Fender sound, but once the track is mixed there aren't too many apologies to be made.
GibsonLover is offline   Reply With Quote
Old 03-19-2010, 01:12 AM   #7
kldguitar's Avatar
good idea
good ideas, we alawys want change our Gt5h into TMB. it is good.
kldguitar is offline   Reply With Quote
Old Yesterday, 03:25 PM   #8
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Steve Ahola
I wonder if that 10uF cathode bypass cap on the second stage of G-10 is actually there... if so, it would just about defeat the NFB loop.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Fender Princeton Recording Amp Enzo Maintenance, Troubleshooting & Repair 12 10-20-2009 12:10 AM
Audicity recording problem in a new built PC Dave N. Fun with computers 4 01-18-2009 11:50 PM
recording drums frosty55 Music Electronics 0 08-22-2008 01:24 PM
Small tube amp for direct recording ? possible? _Chris_ Theory & Design 6 07-02-2008 01:03 PM
Recording Engineering Books? tbryanh Theory & Design 6 05-25-2007 12:33 AM
