Originally posted by ca7922303
View Post
Laney TT50H No Outout
R13 looks burnt, the ones around it look like they got soot on them from R13.
Dear lord. Did we ever post a schematic for this thing? I'm not going back to read through 200 posts to find out.Education is what you're left with after you have forgotten what you have learned.
Originally posted by The Dude View PostThere is obviously a short (or near short) somewhere on the 5V line. You'll have to track it down. Since the supply side of the regulator is also quite low, my first suspect would be the regulator itself. I'd remove the regulator and see if the resistance reading on the rail is still low resistance.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
R13 burnt. R13 is a pullup for pin 4 of U2. Pin 4 of U2 also connects to a pin on the 15 pin "switches" connector. SK3 pin 14. I suspect something bad happened in the switches and burnt up that resistor and likely damaged U2.
SInce R13 pulls up to +5 and U2 is powered by +5, that might explain the dead 5v regulator U6. WIth U6 removed, does +12v appear on the input pin connection?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostR13 burnt. R13 is a pullup for pin 4 of U2. Pin 4 of U2 also connects to a pin on the 15 pin "switches" connector. SK3 pin 14. I suspect something bad happened in the switches and burnt up that resistor and likely damaged U2.
SInce R13 pulls up to +5 and U2 is powered by +5, that might explain the dead 5v regulator U6. WIth U6 removed, does +12v appear on the input pin connection?1 Photo
Originally posted by ca7922303 View Post
Also, R43 now is (0.9mvdc/0.9mvdc) V1-V6 #9-#5(6.6vac) hum balance pot(5.2mvdc/5.2mvdc), R52(0.0vdc/0.0vdc)R43(4.7k ohms resistance)
Also, see burn marks at HT which reads (-236vdc), left fuse pin reads(-452vdc)right fuse pin(0.0vdc) all three(3) grid pins read(-39vdc)Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
