I'm not sure what your point is. Maybe I'm missing something. Of course, a good 470 ohm resistor will measure 470 ohms. The point g1 is making is that it is not the correct resistor value.
Laney TT50H No Outout
Originally posted by The Dude View PostI'm not sure what your point is. Maybe I'm missing something. Of course, a good 470 ohm resistor will measure 470 ohms. The point g1 is making is that it is not the correct resistor value.
Then someone had installed the wrong value part in there. It needs to be 4.7K (4700 ohms).
(edit: you had found original part burnt on pg.2 of thread, maybe it was unreadable and you ordered wrong value?)Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostThen someone had installed the wrong value part in there. It needs to be 4.7K (4700 ohms).
No suggestions, you should be good to go ahead with the sound test.
While you are doing it, check to see if the hum pot is making any difference in the hum level as you turn it.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by ca7922303 View Post
Still only able to get sound out of return efx jack and line out jack.
So when you put signal into FX return, do you get sound at the speaker? That tells you whether the power amp section is working or not.
To test the preamp, you put signal into the guitar input and see if there is signal at the line out. (you would need to send line out signal to another amp)
Originally posted by g1 View PostSo when you put signal into FX return, do you get sound at the speaker? That tells you whether the power amp section is working or not.
Put a patch cord between FX send and return jacks. Plug your signal into guitar input and see if there is any sound.
If not, connect fx send to another working amplifiers input. See if there is sound there.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostPut a patch cord between FX send and return jacks. Plug your signal into guitar input and see if there is any sound.
